E8267D and E8267D labview drivers for Agilent Technologies
Does anyone have labview drivers for E8267D PSG vector signal generator and E8267D PSG analog signal generator?  I download IVI drivers for those two instruments from Agilent Technologies website but they are written in C++,VB code....etc.  It contains only one Labiew code example to show you how to convert the code manually.  I wonder if anyone already converts those drivers into labview code, it will save my time to develop my own.
Thank you,
Happysky
Message Edited by happysky on 01-12-2006 08:46 AM
(3,477 Views)
Have you already requested an instrument driver from the Instrument Driver Network?  If you haven't I would recommend that you do that.  Also, if no one responds with a LabVIEW version of the driver, I would recommend finding a plug'n'play driver for other Agilent signal generators and start from there to build your own driver.
Logan S.
(3,446 Views)
Maybe these are close enough to get started. These models were grouped with the same instrument on the Agilent site.
(3,437 Views)
