ECG using NI myRIO
Hi im new to labview. Any idea how to build an ECG program on labview that is implemented on myRIO, that accepts analog input from the patients electric impulses.
(2,399 Views)
Hi dacabesas,
im new to labview.
You may start with the beginner resources offered for free in the header of the LabVIEW board.
Then you might start with examining the example VIs/projects coming with LabVIEW and myRIO.
After doing so you should be able to read in analog voltage signals: this would be the first step.
Analyzing those signals is a different step - and different question…
(2,378 Views)
