ECU M&C error code -301071
     I have been using the ECU Toolkit for several months in conjunction with a LabVIEW application. The developer of software for our parts ECU just made small modifications to the a2l file for the customer. Now I'm getting an error code of -301071  in the MC Read NChan NSAmp 1D Wfm.VI.
    He is listing the changes as different addresses and additional messages. If the names of the messages we are using have not changed then I don't believe we should be seeing this error.  Any feedback would be appreciated.
(2,361 Views)
Hi Katg^2014,
If you're using the ECU Toolkit, you'll want to post your question to the forum below:
AUTOMOTIVE AND EMBEDDED NETWORKS
https://forums.ni.com/t5/Automotive-and-Embedded-Networks/bd-p/30
This will be the best way to get some eyes on this issue.
Jiwhan S.
Technical Support Engineer
(2,327 Views)
