ECU MC Error -301048 CCP Communication
at different test rigs within my company we use our standard ECU (used with different products) with a custom software version tailored to our testing needs.
We are sending different commands (defined in an .a2l file) and the ecu responds with the correct behaviour (e.g. sending current signals). Currently this process is done within CANape via a CCP protocol. A seed & key algorithm is not performed and no corresponding file is available.
To test whether labview can meet our requirements for a new test rig automation software standard, i want to communicate with LabVIEW and the ECU M&C Toolkit to mentioned ECU.
I'm using a NI USB-8473 as CAN-Interface, which is showing correctly in NI-MAX / NI-CAN.
Whenever i try to execute MC ECU Connect.vi - NI Error -301048 occurs. Possible reason: "ECU Measurement and Calibration Toolkit: A DLL required for communication with the slave device(s) could not be loaded. Verify that this library is installed."
Nothing can be seen on the "XCP and CCP Trace" window, when trying to call mentioned VI.
I'm using LabVIEW 2021 SP1 with ECU M&C Toolkit 2022 Q4.
In the attachments you'll find the used .a2l file and a screenshot of the error message.
I'm grateful for any help.
- Kai
(3,346 Views)
This question is best to be posted on the Automotive and Embedded Networks
Did you use CANx or CANx@nixnet as Interface input for MC ECU Open.vi?
Can you attach your code and the CCP/XCP trace?
https://tmesystems.net/
(3,337 Views)
I use CCP:CANx as protocol and interface.
Attached to this you can find the ZIP as before but with the code and a screenshot added.
On the Screenshot you can see the VI with the resulting error an an the bottom left the CCP / SCP trace and on the bottom right the NI-CAN Bus-Monitor.
Using the Code:
1) Chose A2L Database
2) Select NI-CAN and CCP:CANx
3) Run Script
4) Change SEED GET 2 Button to proof functionality with SEED GET LED
5) Try to read a parameter (e.g. "iAIM1.D_Factor", defined in A2L)
- Kai
(3,273 Views)
Accepted by topic author Cav3
Based on the colour of the LabVIEW logo, you are using LabVIEW 64-bit. NI-CAN driver is not supported in LabVIEW 64-bit. That's the reason why you are seeing missing DLL error.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000004BSsSAM&l=en-CA
https://www.ni.com/en/support/documentation/supplemental/21/migrating-ni-can-applications-to-ni-xnet...
(3,262 Views)
