ECU Measurement and Calibration Toolkit does not run when I build an executable.
I have made a LabVIEW application that communicates with a target using CCP (with ECU Measurement and Calibration Toolkit).
The LabVIEW source code runs OK, but when I build an .exe file it does not work.
I have tried to copy  the ECU Measurement and Calibration Toolkit dll:s to the same folder as the .exe file, but I still get fault messages.
What do I need to do to get the .exe file run?
(3,847 Views)
what you mean by "exe not running"..
Is it broken?
is it broken becasue it can not find certain vi or dll's or some thing else?
Can you a little bit more elaborate on this?
Guru
Regards
Guru (CLA)
(3,845 Views)
Hello Guru,
I run the exe file on a laptop with LabVIEW run-time engine only.
When I tried the first time to run the exe file I was asked to find niemc.dll.
To find the dll I copied the folder "C:\Program Files\National Instruments\RT Images\ECU Measurement and Calibration Toolkit" from the computer where LabVIEW is installed to the laptop where I run my exe file.
Then I got the error message: Error -301113 occured at MC ECU Open.vi
MC ECU Open.vi is really the first vi that this application tries to run.
Rolf
(3,834 Views)
Accepted by topic author Rolf_Weibull
Did you created an "installer" and installed  on the Laptop?
If yes have you selected this tool kit (ECU Measurement and Calibration Toolkit) to add to the installer while creating the same?
Just try this approch once...
Regards
Guru (CLA)
(3,816 Views)
I tried your suggestion and it worked! Thank you!
Is this really the only way to solve the problem?
Is it not possible to install some kind of run time engine that includes the ECU Measurement and Calibration Toolkit files?
Rolf
(3,802 Views)
I realize this is a response to an old post, but there is no run-time license required to deploy executables with the ECU Measurement and Calibration toolkit.
(3,358 Views)
