EEG like waveform chart
I like to plot let's say 30 EEG signals on a single waveform chart. Without the stacked plot option, the signals can i cross eachother but has to have a certain offset... Is there a standard way to do this? I can give each signal a certain offset, but i was wondering if there is some "xcontrol" waveform chart out there with these features? Every EEG viewer has it's graphs in thes ways.
Thijs
(4,704 Views)
Hi I'd be interested as well.
Who
(4,692 Views)
Accepted by topic author ThijsBoeree
You could programmatically provide each EEG waveform with a certain offset, if it doesn't impact on your data. My thought is that you could iterate through your array of waveform data and incrementally add known offset to each curve, which grows in proportion to the iteration count.
Something like below:
Alex Thomas, University of Manchester School of EEE LabVIEW Ambassador (CLAD)
(4,663 Views)
Hi ThijsBoeree,
                                     Your egg is ready, but some extent. Let me know is it ok with you or you want better shape.
   Just run it.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(4,645 Views)
Hi Ranjeet_Singh
I don't know what you want with this vi? But the offset story is what i've expected, so i'l have to stick with that, when it's finished i'll post it here, for anyone to use.
Thijs
(4,637 Views)
@Ranjeet_Singh wrote:
Hi @ThijsBoeree,
   Just run it.
EGG!Smiley Very Happylmao
(4,622 Views)
