ELVIS 1 AND ELVIS II LABVIEW VIs COMPATIBILITY
I am currently working on a project that was previously using Labview (8.5.1) vis built for elvis I, we have now moved on to Elvis II and are experiencing problems that are believed to be steming from the differences in channel configurations. Could some one be as kind to avail channel configurations for both elvis I and Elvis II and what modifications we may need.
(3,700 Views)
I think you might have a problem here. Not only have you not explained What "Elvis" is, but anyone trying to help you with searching just on the info you have given is going to just get loads of Elvis Presley related trivia and not be able to assist in any sensible way unless someone else is working with Elvis and LabVIEW (in which case you probably have a competitor - who is not likely to want to help).
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
(3,687 Views)
James,
ELVIS
(3,678 Views)
Genius thanks for enlightening me Dennis
(3,675 Views)
I see Elvis II has a new lockdown mechanism to prevent theft. So I guess "Elvis has left the building" no longer applies 🙂
-AK2DM
(3,661 Views)
First, I want to reference you to the support page for the NI ELVIS II and its help manual.
NI ELVIS II
https://www.ni.com/en-us/support/model.ni-elvis-ii.html
NI ELVISmx Help
https://www.ni.com/docs/en-US/bundle/372500f/page/download.html
I want to verify what exactly is going on in your program when you upgraded to NI ELVIS II.  Are there any errors you are seeing?  Are you able to get it working in Measurement and Automation Explorer?  Also, what drivers are you currently using?
Jordan F
(3,634 Views)
