ENET 9163 datasocket
Thank you very much, it works perfectly =D
Message 21 of 23
(491 Views)
Hi again, please, I'm using ENET 232/2 device also, I will receive a serial signal, and I have to read it via ethernet
I have use VISA serial for to do this or is required a different block on labview?
Message 22 of 23
(481 Views)
Hi Bechard,
This thread was originally opened for errors when configuring the 9163, not the ENET/232 you are currently having problems with.
When you have a new issue, I would advise you to please first search on the forums for related issues that other users have experienced so you can learn from them. In case you don’t find a related thread, start a new one so we can keep thing ordered.
Thank you.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
Message 23 of 23
(476 Views)
