EOF detection in "Read From Spreadsheet File"
Accepted by topic author hazibuli
Wrong guess.  I just re-read the posts and I see that you want to just read one line at a time.  You have to tell the Read From Spreadsheet File to just read one line, not the entire file.  If you would read the help section on this function you would have been able to figure out what to do.  Here is an example that will read one line at a time in a While Loop.
- tbob
Inventor of the WORM Global
Message 11 of 13
(1,375 Views)
Thanks a lot tbob,
this is pretty close to waht I wanted. A very elegant solution indeed.
Message 12 of 13
(1,362 Views)
Wow,  Thanks a lot!!!!
Message 13 of 13
(1,067 Views)
