EPM_Power.VI Power Factor and Real Power Inccorect. Help
I am using the latest version of LabVIEW and a NI PXIe-1062Q with two PXI 4071 DMM Cards to measure input AC Voltage and Current.  I am using these values to calculate power (Watts) and Power Factor using the EPM_Power.Vi that is in the (EPM) Pallete.  I also have a magtrol 6510e Power Analyzer wired in to ensure that my values match.
My problem is, that, I am obtaining the correct input voltage and current but, my power factor stays either stays 1 when I measure current in digits or is bouncing anywhere from .01 to .99 when I measure current as a waveform.  Also when I measure current as a waveform the value is jumping all over the place.
Example: The magtrol power analyzer will say:
Input Current: 0.634
Input Voltage: 237.75
Power: 141.56
Power Factor: 0.943
LabVIEW will read:
Power: anywhere from 1.34 to 198.68 when current is measured as waveform or same as Volt*Amps when current is measured as digits
Power Factor: anywhere from 0.22 to 0.99 when current is measured as waveform or 1 when current is measured as digits
Please Help
I have attached two VIs showing both attempts.  Oh the first VI works fine to measure DC Voltage and Current but AC is where is gets tricky.
Scott
(3,126 Views)
(3,102 Views)
