ERROR 1073807339
check if your charachter termination is correct
Paolo_P
Certified TestStand Architect
Certified LabVIEW Architect
National Instruments France
Message 11 of 22
(8,973 Views)
Hi, thank you for your answer.
I checked the charachtere termination. it's written in page 70 in the manual.
I also cheked with a feed line and a carriage return but without success 😞
any other suggestion? this intrument is driving me crazy :'(
Message 12 of 22
(8,966 Views)
Get a special serial adapter that splits the signal into two.  Feed the extra port into anothe serial port on your PC.  Open up a program that just reads that port and logs what comes in.
Run the manufacturer's program and log the data it sends.
Run your VI and log what it sends.
See what the difference is.
(There should also be some software that can do this internally on the PC without needing the hardware.  I just don't remember which software that is out there that can do this.
Message 13 of 22
(8,957 Views)
Deleted response.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 14 of 22
(8,942 Views)
@RavensFan I will try this solution and keep you updated
Message 15 of 22
(8,918 Views)
So I used the program Serial Port Monitor to see the instructions. (Because as I said it before the connexion is working with it own program but not working with labview) what the program is sending is this code while connecting to the com11.jpg
and I am sending the same code via NI-MAX but I am still getting the timeout error
 Any Idea please ??  all the setting are right :S I just dont understand
Message 16 of 22
(8,899 Views)
I can observe that you add the Termination Character in your command.
Can you take a look at the configuration Tab and I/O Settings to see if it not already activated.
Paolo_P
Message 17 of 22
(8,894 Views)
It sure looks like it is sending the same command.
I can't tell from the screen shot, but you said you looked at it, so I'm going to asssume you have the baud rate, parity, stop bits all matching.
You are using the same com port, I'm going to assume you are using the same cable, so I doubt you have an issue with the wrong cable.
My last thought is that it is using some sort of flow control, possibly hardware.  That the manufacturer's program sets the RTS or DTR lines, but the LabVIEW program or VISA test panel is not, so the device is not seeing the signal saying it is okay to send data.
Using a device such as this can tell you if any of the other hardware lines on the serial port are being used.  http://connections.advantech-bb.com/search?p=R&srid=S12-USESD01&lbc=bb-smartworx&w=serial%20tester&u...
Message 18 of 22
(8,880 Views)
Paolo, wouldn't that extra termination character show up in his port monitor? From what I can see, the written data matches up with the other program.
marwah, can you share a screenshot of both the configuration of your working application and MAX?
Cheers
Message 19 of 22
(8,878 Views)
Good morning,
Yes I can; this is the confirguration of the program and my windows. the program doesn't show the setting of the port even if you go settings or file...
and these are the settings of my NI-MAX connexion
I also tried to change the time out till 5000ms but still the same error.
You have to know that I am using a converter usb\serial and that when I am using a direct USB connection I am not getting errors but always getting \01' as an answer for any request sent.
I looked for the meaning of that \01' in the manual but it doesn't even exist.
(if you are wondering why am I using a converter if I have a direct USB connection.. My manager want to use a serial connection :S)
You will also find attached the manual of this instrument.
Message 20 of 22
(8,852 Views)
