ERROR 4803 cause my "Sound File Read Simple.vi" error
(3,500 Views)
Hi guy from China,
I guess the problem is in your WAV file.
Unfortunately all we got is an image with the error message, but not the WAV file itself…
(3,487 Views)
Accepted by topic author 劉彥均
You got Chinese characters in the folder name and filename.
Have you tried a full English path?
George Zou
(3,478 Views)
hey, guys I slove this problem with all English name . Thank you for your help.
(3,346 Views)
You should mark Zou's message as the solution to your problem since he told  you to try an all English path, not your own thank you message.
(3,338 Views)
