ERROR AFTER COMPILING
I have writted a vi that runs correctly in design mode and runs
correctly when compiled and installed on a hard drive that has LabVIEW
also installed on it.
When I try to run the compiled program on a computer that does not have
LabVIEW resident on the hard drive the program does not run and I get
the following error message:
ERROR -1073807202 occured at in SpecanRemoteOp.vi
Possible reasons:
VISA: (Hex 0xBFFF009E) A code library required by VISA could not be
located or loaded
Am I missing a file in the compiled version ?
If anyone has an idea please help
(3,202 Views)
Hi Donald
Have you installed VISA on the new PC?
If not you will have to.
Tim
> Possible reasons:
> located or loaded
(3,202 Views)
Timothy,
Thanks for the tip, I needed to add "visa.dll and visa32.dll" to the windowsa
system directory.
Chip
Timothy John Streeter wrote:
> Hi Donald
> Tim
> > Possible reasons:
ISA could not be
> > located or loaded
(3,202 Views)
