ERROR: Dequeue Element in Acquire Semaphore
Hi
Here's the full error I'm getting:
A Run-time error has occurred in step: xMCP Alive?
Sequence: MainSequence
SequenceFile: R:\HLXC1536\Seq\FCU.seq
Error Message: Dequeue Element in Acquire Semaphore.vi:1->NI_InternetTK_Core_VIs.lvlib:Telnet
Read.vi:1->TelnetReadWrite.vi->TelnetReadWrite.vi.ProxyCaller
Error Code: 1
Could somebody please give me a hint to what sort of problem I'm looking at?
The error only shows up when I select to run another UUT (from the preUUT sequence).  If I select no and let the sequential model finish the test, it will not happen on the next run.
The error itself is in a ReadWrite Telnet vi which works fine.  It happens on the first time it is used after the open telnet vi.  Again, it only happens when I select 'Yes' on the question 'run another UUT'.
And thought?
Rafi
(4,217 Views)
Seems that your error is related to TestStand. So, you may need to post here.
- Partha ( CLD until Oct 2027 🙂 )
(4,198 Views)
Have you solved your "Telnet Dequeue Element in Acquire Semaphore" problem?
Roger
(4,011 Views)
