ERROR IN DAQMX TIMING SAMPLE CLOCK
Hi, I am getting an error while using DAQ Assistant. The error message is "the top-level vi was stopped at wire on the block diagram of daqmx timing (sample clock)". Even a simple DAQ assistant is not working. I am using NI USB 6341 and Labview version 2021. I have verified the version of DAQmx and repaired it and even installed it again. But nothing worked. Can you please suggest what would be the problem?
(801 Views)
Avoid using DAQ Assistant. It's buggy.
Use the shipping examples instead. Go to toolbar Help >> Find Examples >> Hardware Input and Output >> DAQmx >> Analog Input
https://tmesystems.net/
(765 Views)
