ERROR:Xst:415 - Synthesis failed
I try to compile my FPGA VI but the compilation fails with the following error dialog box:
ERROR:Xflow - Program xst returned error code 1. Aborting flow execution...
(4,034 Views)
Unfortunately the error codes provided by the Xilinx compiler are not very detailed. Can you provide more information about your VI or the compile report or even attach your VI to a post?
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(4,021 Views)
