ERROR
Hello Every one....
  Iam hardly struggling about an error of -1073807339...i have attatced a image of my error vi....problem is accuring at READ VI...
     Plese help me to solve...
(4,422 Views)
Need more details..
how many bytes you are reading (1024) in that case are you able to read complete data?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(4,416 Views)
no sir i can't able to read data due to error...but in hyper terminal iam getting data...
(4,408 Views)
First close hyperterminal and try only from labview application.. In that case use highlight.. use proper com port. is com port showing in labview i.e from visa resource view?
When reading from LV ensure data is avaible on buffer i.e other device is sending the data
--Ranjeet
(4,398 Views)
yes sir other device is sending data..and com port is showing...or plsese attach a serial data read vi....
(4,390 Views)
Accepted by LV_Pro
Check this.
Ensure same baud rate, proper com port selection and enter number of byte before running the application
--Ranjeet
(4,361 Views)
Thank you Mr.Ranjeet_Singh
(4,330 Views)
