ETSAPI.DLL wissing error
I am trying to recreate an executable on another machine. I copied all necessary files over. When I try to run the executable I get a system error that says ETSAPI.DLL missing.
Any thoughts on why?
Both computers are the same model with the same software installed. Windows 7 pro 64-bit
Thanks!
(4,433 Views)
You obviously did not copy all of the necessary files. Copying its a bad idea. You should create an installer.
(4,382 Views)
JoshS06,
You might want to also look at this forum thread: http://forums.ni.com/t5/LabVIEW/ETSAPI-DLL/td-p/1985979 there are a couple different things people tried to get rid of the error.
Overall, I would agree with Dennis and say that the installer is right route to go.
Aaron L.
(4,295 Views)
I had the same problem. After lots of chasing I found that I had copies of two of the national instruments .dll files in the same directory as the executable.  They must have been an old version or something, when I deleted thouse two files and let the program find the .dll's in the proper location the error went away.
(4,007 Views)
