EXAPROM PDF ERROR 1386
Dear,
I have installed Exaprom pDF Vis on LabVIEW and i have tried to use it to create reports of my VI.
But everytime i RUN, it gives me ERROR 1386 inside the New PDF.vi
Could you please help me?
I have attached the VI and the error.
Thanks a lot
(6,725 Views)
I would say that you either didn't install the itextSharp dll or didn't installed it correctly.
http://decibel.ni.com/content/docs/DOC-10952
Ben64
(6,706 Views)
So, it does work in your PC?
I try to re-install everything.
itextSharp dll is already inside the folder, right?
I only have to Disblock it?
(6,701 Views)
Still doesn't working.
I attached you the itextSharp property window.
Do you see any problem here?
(6,698 Views)
Have you already seen this other discussion?
Problem printing to PDF
http://forums.ni.com/t5/LabVIEW/Problem-printing-to-PDF/m-p/3083217#M881156
Enrico
(6,651 Views)
hi
did you manage to get rid of that error?cuz im stuggering with same error
thanks
(5,214 Views)
