EXE build issue
Hello all,
I have tried to build an exe for my application. but this error was throwing all the time. pls, post your views. I have tried in other systems it is working fine. So, I am suspecting the issue was with the particular desktop.
Note: In the particular desktop I have installed LabVIEW 2015 ( 32 bit ). the desktop was with a 64-bit config
shall i reinstall with a 64-bit config?
(3,284 Views)
This is caused by the mentioned VI. Is Excel is installed?
You could open the VI, and check if it has an error. You might even be able to fix it...
(3,265 Views)
Hi carya ,
MS excel 2007 version was already installed. In that error message, it shows like that. but i have tried in other systems , it was ok .
That's why i asked you . Shall i reinstall the Report generation toolkit once again
(3,254 Views)
I'm not too familiar with the report generation toolkit. Is there a 64-bit and a 32-bit version? Since the VI doesn't have a diagram (at least the message says so), could it be that you've installed the 64-bit version on a 32-bit LabVIEW or visa versa? Note that the OS version doesn't matter. The LabVIEW version is what's important.
(3,242 Views)
