EXE built in XP crashing in Windows 7
Hi Ppl,
I have an application built in Windows XP Service Pack 3. When we tried running it in Windows 7 station it crashed before opening up the front panel and below is the crash details. However if we built the application in the Windows 7 station itself it works fine. I tried running the application in compatability mode, it didn help. The error message points to a dll in the run time engine. The DLL was located in the correct location as expected.
I'm using LabVIEW-2010 SP
  Problem Event Name:APPCRASH
  Application Name:Application.exe
  Application Version:0.0.0.1
  Application Timestamp:4c24e8f5
  Fault Module Name:libappweb.dll
  Fault Module Version:2.4.0.49156
  Fault Module Timestamp:4c212a85
  Exception Code:c0000005
  Exception Offset:0001ba4c
  OS Version:6.1.7600.2.0.0.256.1
  Locale ID:16393
  Additional Information 1:0a9e
  Additional Information 2:0a9e372d3b4ad19135b953a78882e789
  Additional Information 3:0a9e
  Additional Information 4:0a9e372d3b4ad19135b953a78882e789
Sathish
(3,519 Views)
Guys, Any help ? Is this a difficult question ? Should I try NI support to get this solved ?
(3,501 Views)
The solution would be in the following links:
http://blogs.technet.com/b/askperf/archive/2008/06/17/to-dep-or-not-to-dep.aspx
http://digital.ni.com/public.nsf/allkb/D12F9263065435DA8625784F006ECFD4?OpenDocument
Please revert back if the problem is not solved.
Sahil Singla
Applications Engineer | National Instruments
(Give Kudos to good Answers and Mark it as a Solution if your problem is Solved)
(3,466 Views)
