EXE file in LabVIEW 6
Can anyone Tell me That how to create EXE File of LabVIEW Application?
(2,859 Views)
Look at Menu bar: Tools -> Build Application or Shared Library (DLL).
There you get a Dialog where you can specify the option for your "exe". When you have finished this press the "Build"-Button.
Hope this will help you!
Stephan
(2,859 Views)
If you don't see the information above, then that means you have to buy the app builder or upgrade to the pro version of LabVIEW.
(2,859 Views)
