Easy Print Front Panel VI changes Graph on PDF file
I am having a very strange behavior. I have a VI that contains a graph with 11 pens. One pen is on a second scale. When I print this front panel the line on the graph for the 11th pen is inverted. the scales have not changed. I have tried to create a new vi and it worked once until I saved the vi. I have tried 3 different drivers and they all do the same thing. I used the same code before without any problem on another project. I also tried using the report building method which worked but the graph turned out small and distorted on the file. I am running version 17 on windows 10 pro. I am running out of ideas.
Message 1 of 11
(6,977 Views)
It worked for me when I replaced the print VI with the one recommended in the Help file, on LabVIEW 2018 though. You can try the attachment, I back saved for 2017.
mcduff
Message 2 of 11
(6,969 Views)
Mcduff,
When I try to open the file I don't have the vi you changed to. Is this a new vi for 2018?
Message 3 of 11
(6,931 Views)
I do not know, I have never used these VIs before. On your original post, the VI you used had a big red X on it. In the context help, it said it was deprecated and suggested another VI. I do not have LabVIEW here to check. Will update you a bit later.
mcduff
Message 4 of 11
(6,928 Views)
The VI is located in the following directory:
Program Files\National Instruments\LabVIEW 20XX\vi.lib\printing\EasyPrinting.llb\Print VI Panel or Documentation
Can you check if it is in your 2017 folder?
mcduff
Message 5 of 11
(6,919 Views)
I found the vi and it does the same thing. It prints the green pen starting from the top instead of the bottom.
Message 6 of 11
(6,915 Views)
Accepted by topic author markofdiego
Your right Y axis is Log-scale.
Your first data point is exactly zero. Apparently, Labview have issues with displaying zero on log-scale.
If you change your first data point of first (not 11th) plot to something like 1e-20, for example, then it prints correctly.
As for obsolescence - LV2018 obsoleted "standard report" report type which is used for simple printing VI.
I have always found Reports to be a bad fit for printing front panels. It messes up scales sometimes.
If you want to just send front panel to a default printer you can use attached snippet.
If you want to use custom printer, you are probably better of using .net printing function. It is a bit more work but you can have a very precise control of scales and page parameters.
Message 7 of 11
(6,912 Views)
And attached is your VI with fixed data point value just so that you can run it yourself
Message 8 of 11
(6,909 Views)
I was about to suggest something similar to mikhail, that is, using the FP.Get Image method. You won't get a pdf, but does a png work for you? Also, good catch by mikhail on the log axis, note on 2018 printed okay.
mcduff
Message 9 of 11
(6,907 Views)
I appreciate the input. I will try to update this to get rid of the zero.
Message 10 of 11
(6,904 Views)
