Easy Question? .GBL files...
I have a feeling this is an easy one, but...
I have a .GBL file that I need to change. I'm not quite sure what this file is. I have a feeling it contains a bunch of global variables, but I am only able to open the Front Panel (the block diagram is not available).
What is this file and how can I change (and save) some of the values in it.
Thanks much,
Russ
(3,527 Views)
Hi Russ,
You're right, this is a global variable VI. Global VIs do not have diagrams. Once you change the values, you can go to Operate > Make Current Values Default, then save the VI. Your values will now be persisted the next time you open the VI.
I also recommend re-naming the file to have a .vi extension, since Global VIs are, well, VIs!
Let me know if you have any other questions on this topic.
-D
(3,527 Views)
