Easy Question
I haven't used LabView for a few years and have a quick question.
I have a .llb library which I need to edit the front panel of the
"top-level" vi.
However, the .llb is set up to be run whenever opened.
How do I edit the main vi?
I have tried the File-> edit vi library and removed the "top-level"
setting. However, when I try to File->Open the .llb it just runs
again.
Help!
Thanks.
(3,051 Views)
Try to press: Ctrl + Dot
Br
www.mypuzzle.dk
"Rock Braud" wrote in message
news:a46be137.0111012022.500c5f85@posting.google.com...
> "top-level" vi.
> again.
> Help!
> Thanks.
(3,051 Views)
Rock,
Open LabVIEW, and create a new VI. Right-click in the diagram, option
'Select a VI', selcect the llb, select the main VI.
Dubble click it to open it, and it is not running. (Shortcut: Ctrl-dubble
click, also opens the diagram)
Wiebe.
> "top-level" vi.
> again.
> Help!
> Thanks.
(3,051 Views)
Thanks for the help.
I knew there was some "secret" keystroke.
Thanks again.
"AIR" wrote in message news:<9rtne4$g5g$1@news1.xs4all.nl>...
> Rock,
> Regards,
> Wiebe.
> > "top-level" vi.
opened.
> > again.
> > Help!
> > Thanks.
(3,051 Views)
