Easy Text Report
I try to print out a text with "Easy Text Report.vi".
After the "Set Report Margins.vi" there is an error: Menmber not found!
What´s wrong?
Thanks, Philipp
(2,759 Views)
Hi Philipp,
I had the same problem, try this:
- In the Measurement System input of Set Report Margins vi connect a constant and set it to metric or US
- In the report margin cluster try to change the default values ( I set 10mm)
In my case this worked. This problem showed up only with LV6; LV5.1 worked fine.
Good luck,
Alberto
(2,759 Views)
