Easy one: How do I change the default text color for a digital indicator without using attribute nodes?
That's it. I'm just working with aesthetics and I;m wondering how one changes the color in a digital indicator. I used the color tool but it only changes the box itself, not the text.
-Dobbs
(2,941 Views)
Dobbs,
Select the text tool and place the cursor in the control field and highlight the number/text. Click on the Font drop-down menu on the toolbar, select color, and select your color. Voila!
Mark
(2,941 Views)
Select the text that you want to change the color of and use the font pull down menu to change the color.
Brian
(2,941 Views)
select the text, and then change the color. If you want to permanently change the color, you probably have to modify the typeDef. I would suggest not changing the LV typeDef, because it will change all instances of digital indicators. Instead change the typeDef and save it under a new name.
To change that, drop a digital indicator in the front panel, select it and then Edit>>Customize control. A window will open where you can change the indicator and save it under a new name (*.ctl). Start using the new control from the file now.
Hope this helps
A Rafiq
(2,941 Views)
