Edges around window
I would like to remove edges (3D effect) around window (see attached picture). Is it possible?
Andrej
(3,638 Views)
Hi Andrej,
I'd suggest using the Get Image Subset VI. This VI allows you to specify a bounding box to cut out from your image based on data specified within a cluster called 'Subset Rect' (Left, Top, Right, Bottom) which specifies the pixel co-ordinates of each corner of the selection region. The image is taken as Image Data; a String which can be generated when using the Read JPEG/Read PNG/Read BMP VIs.
Alex Thomas, University of Manchester School of EEE LabVIEW Ambassador (CLAD)
(3,620 Views)
Hi Alex,
I wasn't clear enough before. I'm not trying to get an image of a front panel, but I would like to remove this edge (3D border) on a window in run-time. This edge (3D border) appears when you remove title and menu bar.
Was I clear?
(3,610 Views)
In the VI properties (ctrl+i) -> goto window appearance -> custom -> and turn off resize window and titles bar
_____________________________
- Cheers, Ed
(3,603 Views)
Hi Andrej,
Sorry for my misunderstanding. If you go to VI Properties, set the Window Appearance to 'Dialogue'. Then, deselect the 'Window has title bar' option from the Customize... menu; this should remove the entire window border.
(3,597 Views)
Accepted by topic author andrej
I solved the problem. Actually this effect is only when Window behavior is set to modal. I changed it to floating and now it is as I expected.
Thanks for help.
Andrej
(3,592 Views)
