Edit Plot Markers
I am trying to make my own custom plot axis mapping to match some weibull plots which are neither linear nor logarithmic. I can manually add in markers at the points I need but I cant seem to be able to create them programmatically or change the text on them. I attached a vi snipit of what I am doing to try to change the text. As far as I can tell there is no way to programmatically add the custom markers. Please let me know if there is a way to add them and get a reference to them.
-J
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
(2,576 Views)
Yes, your possibilities are limited. In the mean time feel free to vote for the following ideas:
Custom-Axis-Mapping
Allow-text-labels-for-graph-scales
Thanks!
It would be a bit more work, but I would probably roll my own using a 2D picture indicator. 😄 (as an example, search your example finder for "XY Multi Plot.vi", see image below)
(2,553 Views)
Those two ideas got another upvote each.
I like the 2D picture idea. I already have stock LabVIEW plots all through the application so I would have to roll a 2D picture indicator plot that approximates the look and functionality of the built in LV plots, which sounds like a time black hole. Lets see how that goes.
-J
(2,523 Views)
Well for now I made a solution involving, custom markers, text indicators and mapping functions that works as long as you dont resize it. Next step is to make the text fields track with a window resize.
the mapping VI that maps the %failure ( the nonlinear scale) to the linear scale looks like this,  in case any one else is trying to do this:
(2,511 Views)
could you please attach the VI with front panel above.
(2,448 Views)
Sorry I have a client paying for this development so I can't post the source code for that here. On a side note you can re-create the VI with the snipit provided,  then you can plot the result on a standard XY plot and then make your own scales and it will look suspiciously similar : )
(2,424 Views)
