Edit Substeps programatically by labview
My supplier has delivered a library of steps in TestStand (with a TypePalette and associated Ini Files).
I'd like to custom the INI file with LabVIEW to add a module as "Edit Substeps" on the differents Steps Types.
With "GetTypePaletteFileList" and "PropertyObjectFile", I can see the differents Type Palettes and the associated paths but I can modify it (add a substep module ... etc) ?
Is it possible ? Someone has an idea ?
Thank you for your help
YR42
(2,829 Views)
You might want to post this on the TestStand forum...
Mike..
Certified LabVIEW Architect
LabVIEW Champion
(2,809 Views)
