Edit X scale label from numeric to text in Waveform Graph
Hi all,
I am at the final stage of my project, and I'm finding it quite hard to overcome the last step.
I have a Waveform Graph plotting four value as a bar graph (kind of a histogram). I would like to edit the X-axis scale to insert the name of the four values ( Baseline - Test 1 - Test 2 - Test 3) under their respective bar.
Surfing this and other forums I read that it is not possible to do what I'm trying to achieve, but I actually hope there is a way-out.
I'm using LabVIEW 13.0 (32 bit)
(3,520 Views)
Well according to your reading the impossible was accomplished about 10 years ago...
Ben
(3,511 Views)
I just realized that:
  • Renaming the xscale label in "baseline  (lot of spaces)   test 1 (lot of spaces) and so on" ;
  • Changing the Xscale style to the "empty one"
would be an extreme solution to solve the "external part" of the problem.
But I would love a "normal" solution to it Smiley Very Happy
(3,510 Views)
