Edit a array of Cluster element property
I have a array of cluster .In which i have 1 Ring control and a string control.I want to name different string element property of ring for every index of array. For Example In the first Array the ring display choice is (a,b,c) and 2nd Array the ring display choice (b,d,e). Is this possible ? i am able to only give a common choice display.
With Regards
Sibin K Mathew
Email: sibin.is.here@gmail.com
Mobile No:+1215-406-6545
http://in.linkedin.com/pub/sibin-mathew/48/846/446
Message 1 of 10
(5,606 Views)
Sorry, but every element of an array must have the same properties.  They can have different values, but everything else has to be exactly the same.
Message 2 of 10
(5,593 Views)
Do i have any other way to create a array of cluster with diffrerent Ring display ?
With Regards
Sibin K Mathew
Message 3 of 10
(5,589 Views)
Hi sibin,
again: in an array all elements share the same properties. So you CANNOT use an array when your rings should have different strings!
You can use a cluster of clusters - with a fixed number of clusters in your main cluster…
Message 4 of 10
(5,575 Views)
It's all a question of how many items you put into your cluster 😉
Add label strings or an array of string and your done:)
In your control, you can disable the strings
Greetings from Germany
Henrik
LV since v3.1
Message 5 of 10
(5,568 Views)
It's more coding, but you could use something like this, and then change the items in the ring control each time you show that control at a different location in the table.
Message 6 of 10
(5,545 Views)
Its again , you won't be able to change for the particular string property of ring in an array.
With Regards
Sibin K Mathew
Message 7 of 10
(5,516 Views)
My application doesn't know how many element will be there untill the data is inserted when application starts.so I need to change the ring display as per the input to the string control . It can have min of 20 array elements.
With Regards
Sibin K Mathew
Message 8 of 10
(5,514 Views)
Accepted by topic author Sibin
Sure this can be done with some voodoo magic.  Oh and using a Combo Box instead of a ring.  I think the same is possible with a ring but I wasn't sure if values would get changed where I knew a Combo Box it wouldn't.
Attatched is an example where there is an array of a cluster, with a combo box and a string in the cluster.  Set the string to something and the Combo Box will be populated with names that start with the string in String.  This will create the illusion of different drop downs for each element in the array, but really it is changing the drop down in each element as needed.
Message 9 of 10
(5,471 Views)
Thank you Hooovahh ,This solution is working for me.
With Regards
Sibin K Mathew
Message 10 of 10
(5,444 Views)
