Edit rownames in multicolumn listbox at runtime using keyboard
@Michael.Koppelgaard wrote:
Thank you for your advices 🙂
Nearly there now. Only the position of the numeric is not perfect.
I used Ring control for which there is property called Named Number Size, try to find the same Property for Numeric control to feed height and width
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 21 of 23
(1,099 Views)
Sorry - I cant fint ring control under property notes for MCL
Message 22 of 23
(1,095 Views)
I meant to say i used Ring control in the place of your Numeric control.i am not mentioning about MCL. we can set the size of Ring control based on MCL Cell Size
Message 23 of 23
(1,092 Views)
