Editing LLB leaves temporary file
When editing an LLB under Mac OS X, the temporary copy of the LLB is not deleted. To see this, open an LLB, modify a file and save it back to the LLB. You will find that a file has been created:
/var/tmp/folders.NNN/TemporaryItems/tarc########.llb
Where NNN is your numerical user id and ######### is some sort of unique ID for the library. If you look at your Temporary items folder you may find a lot of old LLBs in there taking up space.
Look at the folder, by opening a Finder window, type Command-Shift-G and then enter /var/tmp. Then you can fidn the correct folders.NNN sub folder. This folder is NOT cleared on reboot so it can get a lot of stuff in it.
LabVIEW ChampionLabVIEW Channel Wires
(3,409 Views)
Duplicated by NI and CAR 437E4IPQ issued. This followup so that CAR can be tracked.
(3,391 Views)
This was reported to R&D (# 437E4IPQ) for further investigation.
This notification posted for tracking purposes.
Chris C
(3,341 Views)
