Editing ini File
Hi, I am using a Labview software created by a third party firm. Now that firm has gone out of business and the software has been rendered useless because of the hardware change in the system.
The software is using ini file to verify the MAC address of the LAN for licensing. Since the motherboard is changed, MAC address is no longer same as the licensed one.
Trying to edit the MAC address in the ini file leaves it corrupted. I am looking for any way to edit the MAC address in the ini file. Attaching the file for the easy reference.
https://www.dropbox.com/s/fqlkq57apeq1kaj/Dev_Setting.ini?dl=0
Could not attach ini file due to following error hence dropbox link
The attachment's dev_setting.ini content type (application/octet-stream) does not match its file extension and has been removed.
Message 1 of 10
(4,604 Views)
so you ask for help on breaking the software copyright protection of that measurement system? Really?
When you want to attach that file you should put it in a ZIP file!
Message 2 of 10
(4,593 Views)
Thank you for  your advice of zipping the file.
I am not asking advice on breaking the software. The original company has shut its shop, Now I am left in limbo.
Message 3 of 10
(4,578 Views)
in my experience there is almost always someone else now the owner of the IP of that company.
You are asking for help on breaking a software protection!
Message 4 of 10
(4,574 Views)
It is possible to change the MAC on a network card. Just saying...
Certified LabVIEW Architect
Message 5 of 10
(4,570 Views)
There are ways to change MAC address on network cards. But on some cards specially built into Dell systems can only be changed to specific series. This is a known issue.
Message 6 of 10
(4,568 Views)
Some claim it is: https://www.howtogeek.com/192173/how-and-why-to-change-your-mac-address-on-windows-linux-and-mac/
Message 7 of 10
(4,558 Views)
You can probably have a read here.
https://blog.technitium.com/2011/05/tmac-issue-with-wireless-network.html
This issue is not uncommon. You will find thousands of posts on this.
Message 8 of 10
(4,551 Views)
Oh, so you need to use a wifi adapter?
-"This issue is observed only on wifi adapters, while you can change the MAC address on Ethernet adapters without any fuss".
Message 9 of 10
(4,545 Views)
The network needs to be always on that particular system and system is connected through wifi as it is placed in atex zone.
Message 10 of 10
(4,543 Views)
