Editing tags with DSC Run-time System programmatically
I need to change programmatically some tag parameters as alarm setpoint using DSC Runtime system. Could I change these and how?
Thank you.
(2,928 Views)
There are some tag parameters that can be modified programmatically while the engine is running. Have you tried checking the set tag attribute vi under the function palletes, tag submenu?
(2,928 Views)
