Editing the Array from Front Panel
I am reading a string spreadsheet from my pc, I want to edit it then save it.
Is there anyway to edit it manually without using replace element in the block diagram ?
(3,647 Views)
Hi El-Awny,
Yes.
Spoiler
Load your data, display them in a frontpanel control element, and save when editing is finished…
(3,635 Views)
Accepted by topic author El-Awny
Or do you want be able to do it while running the code? You speak of element and spreadsheet, so since you attached no code, I guessed what you want. See attached VI.
Certified LabVIEW Architect
(3,627 Views)
