Effect of Mass Compile on VI default values?
Does a mass compile during upgrade from one version of LabVIEW to latest version cause default values of VIs to be reset?  Here and there I set front panel defaults so I can easily do standalone testing of the individual VI.  Furthermore, there are times I keep the defaults for actual application use.
Don
(2,398 Views)
A mass compile should not affect control and indicator default values.
-D
(2,394 Views)
