Elapse time + Excel + write to measurement express VI
Hello Community,
I have been working on a VI that plots a 10 point average of a random number against elapse time and using the write to measurement file express vi to write this to an excel file. The vi works after a fashon but the only way I can get the time column to work is to fractionize seconds into a part day (apparently Excel sees time this way) and when I open the excel file is to format the time column into hhh:mm:ss.00.
Any suggestions or exmples are more than velcome
I guess I must be missing something 🙂
TIA
Simon
(3,424 Views)
What you are "missing" is that computer systems and languages represent TimeStamps differently, especially in the definition of the definition of "Time 0".  For LabVIEW, it is 1 Jan 1904 UTC, while for Excel, it is 1 Jan 1900 UTC.  [Interesting, Time 0 for the Windows File System appears to be 1 Jan 1601, while Unix use 1 Jan 1970].
If you express Time as a String (instead of a number) and save it to Excel, you stand a chance of getting the "expected value".  Otherwise, there are complicated formulas (I haven't convinced myself that I've yet gotten it right) that might allow you to translate between a LabVIEW TimeStamp (numeric) value and Excel's (note that LabVIEW's TimeStamp is a 128-bit number).
I see that you are using LabVIEW 2016.  I know that some "editions" of this version include the Report Generation Toolkit which permits pretty flexible writing of Excel files, and in particular can accomodate writing TimeStamps as strings.  I don't know if this would help your situation ...
Bob Schor
(3,409 Views)
Your time conversion is missing some elements.
Try this:
from here  more information here on why there is no built in LabVIEW function.
Wow, its been a while since I needed to pst that.  That little vi has more solution to posts than any other single vi on the forums (a few String / ASCII conversions come close though)
(3,402 Views)
