Elapsed time Reseting time stamp on Write to mesurment file
I have been trying to have real time data monitored on the front panel with a NI 6009 DAQ card and capture the data into an excel sheet a constant rate. I am using a Elapse time function to capture the data into a excel file every 5 seconds. The problem is that the first value has a correct time of the current time but every other time has a time of the default 1/1/1904 00:00:00.000
I have the auto reset on and I have tried every feedback loop to reset the time properly.
thanks in advance for the help.
(3,759 Views)
Here is an example of the data I'm getting
(3,741 Views)
The main problem I see is your program is "one big loop".
Rewrite it using a proper program architecture like a state machine and properly timestamping your data is a piece of cake.
Fixing this, not so much...
=== Engineer Ambiguously ===
(3,723 Views)
How would I use a state Machine this application? that would just switch between VI blocks right?
(3,712 Views)
What do you mean? Ive looked up THIS tutorial and I'm not seeing how i can apply it to my case. Could you elaborate or point me in the right direction.
(3,642 Views)
Well looking at your program I see several discrete steps
  1. Configure DAQ
  2. Take measurements
  3. Process measurement data
  4. Display measurements
  5. Save data
  6. Manual Mode
If each one of these was a "state" in a state machine, adding a "Timer" state and using the timestamp from that for your data would be easy and future expansion or changes your program are far easier.
(3,634 Views)
