Elapsed time limit
Using LabVIEW 8.5, what is the lower target time limit for the elapsed time function?  Using XP I have sucessfully use 0.25 seconds, but using Vista 32 it appears to be around 0.60 seconds.  Any one experience this?
(2,939 Views)
Hello ProfEdyB,
As I understand your question, you are trying to determine the minimum amount of time for which one can set the Elapsed Time Express VI and receive an accurate result.  I do not have specific information on this use because it is, at least partially, determined by your computer's resources.
Generally, the Elapsed Time Express VI is not used for short (<1 sec) time periods.  I suggest using a Wait (ms) or a Tick Count (ms) VI.  Though these are also dependent on your system resources, they are more appropriate for timing short periods.
If you would like to achieve more accurate or shorter timing periods, you may want to look into switching from Windows to a real-time operating system.  The main benefit of a real-time operating system is determinism.  You can learn more about Real-Time by following the links below:
     http://www.ni.com/realtime/
 Developer Zone:  What is Real-Time?
     https://www.ni.com/en/shop/data-acquisition-and-control/add-ons-for-data-acquisition-and-control/wha...
(2,909 Views)
