Electrical measurement conventions, experiment set-up standards
For the longest time I've been trying to find a single source of information about the proper way to set-up experiments with electrical signals being generated, measured and recorded. There are so many options when choosing equipment and components. Over time I've figured out what I need to know for my specific cases, but I always find it difficult to find the answer I'm looking for. We're so often concerning ourselves with signal integrity, so why is it so hard to find the right information? There's great peer-to-peer passing of knowledge, this forum for example, but that's not the best way to do it.
For instance:
What type of wires should be used when measuring small/large fast/slow voltage signals? What size, material, braided or unbraided, coax, shielded, etc... how to know what to use and when?
How should the connections be (solder, alligator clips, clamps, etc) and what is preferred?
Grounding principles between instruments and the experimental set-up.
Oscilloscope fundamentals
Buffers, amplifiers, differential amplifiers, instrumental amplfiers
Input/Output impedance issues
The list goes on.
What are the common resources you guys use to help figure this stuff out? I feel like there should be a compendium of some sort.
Thanks for the help.
(2,905 Views)
Here's a good standby reference:
http://www.amazon.com/The-Art-Electronics-Paul-Horowitz/dp/0521370957/ref=pd_sim_sbs_b_2
For high-speed digital (which is really just analog):
http://www.amazon.com/High-Speed-Digital-Design-Handbook/dp/0133957241
Keithley app notes. Analog Devices app notes. Old Burr Brown manuals. Texas Instruments.
(2,875 Views)
You can definitely start with Measurement Fundamentals Main Page.
This will guide you to different specific sub categories:
-> Analog Fundamentals
-> Digital Fundamentals
-> RF and Microwave Fundamentals
-> DAQ and Instrument Fundamentals
-> Sensor Fundamentals
Apart from above link, you may also want to have a look at:
1. Electrical Principles Series
2. Signal Generator Fundamentals
This will cover 'generation' and 'measurement' for you..!!
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,869 Views)
I'm not sure what type of experiments you normally perform, but this reference may be of interest... http://www.amazon.com/Electromagnetic-Compatibility-Handbook-Kenneth-Kaiser/dp/0849320879/ref=sr_1_1...
It's a very large book (i think it was around 900 pages or so) on standards/practices in EMC measurements from in depth derivations to overviews.  For example skin deth derivations are included for various cable configurations and the results are summarized in a table.
(2,853 Views)
I think the "compendium" you're looking for is called... Education and Experience.  Smiley Wink
The things you're asking about change from application to application so there's no definitive source that provides all the answers.  It's a good thing really because if there was a source for all engineering answers no one would need engineers.  Smiley Sad
Having said that, the comment about app notes is right on.  There's a wealth of free info out there from companies who want to help you get your job done (and buy their ICs, 'cough').
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,845 Views)
The Art of Electronics should be on every technician's bookshelf.Smiley Happy
PaulG.
Retired
(2,841 Views)
