Elevator Program
How to program elevator with labview?
Kudos and Marked as Solution == Thanks
(7,146 Views)
How to program elevator with labview? Does anyone have the program example?
(7,143 Views)
What are your requirements?  What have you tried so far?  My first thought is that you should look into a State Machine.  Otherwise, we need a lot more details and you need to show an attempt so that we can guide you.
(7,129 Views)
Duplicate thread
(7,125 Views)
@crossrulz wrote:
Duplicate thread
Not sure if this was intended but the hyperlink brings you to the top of this thread.
(7,048 Views)
@Jacobson-ni wrote:
@crossrulz wrote:
Duplicate thread
That is because somebody merged the two threads overnight after I created that link.
(7,041 Views)
There used to be a cute example for teaching notifiers that simulated elevators but NI dumped it after 2013.  Jeff Bohrer has provided the zip file here:  http://forums.ni.com/t5/LabVIEW/Simple-Elevator-Simulator/td-p/2880224
P.S.:  This is an obvious NI example so if you're planning to hand it in as homework expect your teacher to be suspicious.  Smiley Wink
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(7,011 Views)
