Elgar EW3001 Drivers vi's?
Anyone ever used an Elgar EW3001?
I am looking for drivers or vi's, anything...
=== Engineer Ambiguously ===
(2,602 Views)
Hi RTSLVU,
Are you looking to control it through GPIB or RS232?  Do you have the user manual with a list of accepted commands?
Kira T
(2,586 Views)
Probably GPIB, I do have the manual with the command set in it but I was hoping to find this work already done.
Actually the command set is very similar (if not identical) to the SCPI commands the California Instruments 5001iX AC source uses.
So I will probably just modify the VI's I wrote for it.
(2,584 Views)
