Eliminate a particular data from Array
Hello, users and companions of LabVIEW and National Instruments Products, Hello, I'm working in a proyect with 2 Incremental Encoder Mitutoyo, I have a Digital Read Out (DRO) System for read the encoders,
The proyect consist in measure a Parabolic Suspension for the cars; using 2 encoders, in X Length an Y for the thickness.
I have a subroutine for read data from the DRO, then the data are storage in an array.
Then in other sub-VI extract  certain information with the next criterion:
In the information that I obtain I don't need:
1.- Data that are equal to zero in X and Y columns
2.- Data that are equal in X and Y columns
But now I need eliminate the first data from an array (X and Y) between two data that are equals in X Column. (See Extract Data2.bmp) Only I need the second data.
I want if some of you, can I help me? for complete this task.
The VIs what maxe this task is anexed in this mail.
I value your aid. Thanks for your help, Greetings and Blessings.
Ing. Jorge Alonso Cardozo Rodriguez.
(3,731 Views)
Your vi didn't have the real data saved in it.
(3,726 Views)
Sorry Unclebump, here is the VI that I am using for eliminate the conditions 1 and 2, but I need your help for eliminate the data of the third condition, because in the information that I obtain of diferents measures of diferents types of parabolic suspension of cars in the company where I am working; this data is invalid, when this condition is present.
P.D. The data of the VI is only a example, in the real, I obtain approximately 1000 real data, where this third condition is present is in caulquier moment or place with a frecuency of 10 times. This happens because I demand many data to the Serial Port, when I diminish the time for the next read I obtain approximately 700 real data, But I need the greater amount of real data for to reconstruct with one better resolution the parabolic suspension of a diferents models of cars.
I am trying make the changes in this VI but I have little time.
Thanks for your Help.
San Luis Rassini Corporation.
(3,707 Views)
Here is what I did.
(3,667 Views)
Thank you very much Unclebump, thanks to God I resolved the problem, like you, but a little diferent, thank you very much, see you later, you have a friend, in any thing that I can help you. God bless you.
(3,661 Views)
