Eliminate margin around Xcontrol
Hello, all!
 I'm trying to create an Xcontrol using a combo box on the Facade.  I would like to adjust the Facade window size so that when I drop the Xcontrol onto a panel, there is no space between the edges of the combo box and the Facade window.  I've tried to adjust the control and window sizes manually, but it's been a frustrating process, to say the least.  No matter what I do, the Xcontrol window is always larger than the combo box.  Any suggestions?
Slowpoke
Slowpoke
CLAD (believe it or not!), using LabVIEW 8.5
They don't call me "Slowpoke" for nothin'!
(3,018 Views)
I didn't have a specific problem doing this. What version of LabVIEW are you using? Is the attached (LV 8.2) what you're trying to do?
(3,000 Views)
