Eliminating Background Noise using Labview
I have built a VI that is used to measure voltage from an amplifier connected to a photomultiplier tube.  The PMT reads a fluorescent light signal and sends it to the amplifier, which converts current to voltage.  I get a pretty decent signal reading, but I want to cut down the background noise that shows up.  For some reason, the background noise starts around 1.5V and randomly oscillates between 1.42 volts and 1.54V.  I am trying to find a way to cut down the noise so my readings are a little more clean.  I have attached my VI and a picture of the resulting graphs I get from a typical data run.  The left graph shows background noise in a 4second interval, and the right graph shows the complete run.
Any help, suggestions or comments is very much appreciated.  Thank you!
(3,151 Views)
It seems like you have plenty of S/N and can just use a peak detector to get at the essential data.
Otherwise you could try a median filter but it could easily wipe out your peaks if you are not careful.
(3,138 Views)
Looks pretty clean to me.  Just curious, why do you need it to look cleaner than that?
Bill
CLD
(Mid-Level minion.)
(3,126 Views)
