Email Sever
How do I specify the security protocol for an email server when using SMTP email functions.
I would like to auto-generate and send emails on a certain time interval.
I can do so to mail servers such as AOL, Yahoo, etc.
However, the email for the company I work for (Michigan State University) uses TLS protocol.
How can I specify this when using the SMTP functions, and provide log-in information if neccessary?
Cory K
(3,480 Views)
Accepted by topic author Cory_K
The built-in email VIs do not support authentication or security protocols like TLS. You will need to use an alternate method, such as .NET, if you're on Windows, or use the Open G SMTP library. .NET supports TLS, but I don't think the Open G SMTP VIs do. You can find examples of using .NET in the Developer Zone. E.g., : http://search.ni.com/nisearch/app/main/p/y/0/q/tls/x/0/
Message Edited by smercurio_fc on 05-12-2009 12:41 PM
(3,477 Views)
I will mark Smercurio's post as the solution, since he led me there.
But in case anyone comes across the same issue, here is the VI I found that works.
Its the one that says Gmail.VI.
You can edit the server to any TLS server (ie mail.msu.edu in my case).
Cory K
(3,470 Views)
