Email a created text file by the click of a button
Hi
What I am trying to do it that: In the Front Panels, All the data is collected via String Control and other Control, then when a press saved, a text file is created and stored in the path that I specified.
It is possible in LabView to using a Button called 'Email Created File' to then e-mail that file as an attachment.
What VIs or example does such a thing?
P.S. I'm deploying it to a PDA.
Cheers
Message 1 of 13
(5,307 Views)
I have just tried using an SMTP Email Send File, but an e-mail pops up.
Some of the inputs are not real, but please take a look at the VI to make sure I'm in the right direction.
Cheers
Message 2 of 13
(5,286 Views)
Message 3 of 13
(5,284 Views)
Hi TDSquare,
I can't seem to open your VI, no error message pops up either.
Anthony Wong
University of Toronto
Chemistry Department
Message 4 of 13
(5,281 Views)
I used LabView 8, maybe you are using an older version to open it.
Message 5 of 13
(5,268 Views)
Hey,
An Error Code: 10050 is generated when I click the button. First it displays the message 'File has been sent', then I click ok which brings up the error. Are the inputs to the SMTP correct?
Message 6 of 13
(5,249 Views)
Does the Error message appear when you don't try to attach that file (ie: just send an e-mail with no attachment?)
The inputs look OK, so I would suspect it's a problem accessing the attachment file on the PDA - therefore best to check it can send without attachment first.
Best wishes,
Mark
Message 7 of 13
(5,241 Views)
I think the error might be with trying to attach the text file. I'll try to send an e-mail without an attachment.
I'll update you mid next week.
Message 8 of 13
(5,239 Views)
Hi
I tried sending just an e-mail with a STMP Send Email Massage (small) VI, a different error code popped up (Error code 10038).
Is it because it does not know which e-mail account to use? Because the PDA has a Vodafone and outlook account?
The PDA sends an e-mail if I select a file, then send via e-mail and the select vodafone e-mail, then send.
Any ideas please.
Cheers
Message 9 of 13
(5,204 Views)
Hi TDSquare,
I think I may have found an answer for you.   I was getting the same error messages too.
If you disable your virus checker, it should then run.
Try this and let me know how you get on.
Seamus
NIUK
Message 10 of 13
(5,120 Views)
