Embedded LV 8.0 Real-Time application on cFP-2120
Hi!
I'm working on a project which involves programming of a real-time application running on a cFP-2120. The purpose of the application is to control the motion over 7 test-objects with a servomotor.  Test-objects have 3 sensors each. Remote control of the application is necessary. The program should have a GUI which shows graphics of sensordata and buttons to open other VIs like set-up, details, logging etc.
Could i just build an application like it was meant to run on a pc, deploy it to the cFP-2120 and use Connect to Remote Panel ?
Or
Should I build separate VIs;
-the program which always runs on the cFP-2120 and
-the User Interface which is runned on a computer now and then which gets value from Network-Published shared Variables
I need some tips here  Smiley Happy
(2,652 Views)
I would definitely go for the second option, esp. if you want to have this program for a longer time.
It's much easier to write a good GUI on the PC without the limitations of a real time OS. There you have to keep too many things in mind (esp. no dynamic arrays, performance issues due to GUI programming, not too many sub VIs)... So write a quite minimal control software for FP and do all the interface stuff on the PC. Then you can easily log all the data into a database (if you have the DSC Engine) as well.
Cheers,
  Carsten
(2,642 Views)
